Dude Web Access Stop Working
I have a strange problem. Mikrotik Dude WEB Access stop working daily. I have to manually go to settings / Server and uncheck the ENABLE button and apply. then again check the ENABLE button and aplpy, then it starts working again. Web access is important for us as the management uses web access to monitor the network remotely.
Dude is installed on Windows 7 on ESXi. Previously it was installed on HYPER-V , I thought this problem was related to vm, therefore I migrated it, but no use. problem still exists. I even reinstalled the dude and import the backup (more then 500 probes/devices for monitoring)
Sorry I do not have the answer but have had the same problem. I gave up relying on Web access and only enable it when needed (hardly ever). So the problem is not yours alone. My Dude is 4b2 on Win 2003 R2 server on an ESX system.
Thanks for the reply geoffsmith31
The problem seems to be solved after I re.install DUDE twice on ESXi.
Web Access is quite a handy way for management members to monitor the entire network, specially for users with mobile internet access.
Unfortunately, again facing the same issue. Dude web access stops without any error in logs. After checking/Unchecking Web Access, it starts working again.I am using ver 4b3 on win7 on ESXi/ (Also tried on Hyperv) so its not the issue of OS, perhaps something with the DUDE Beta version issue.
Anyone have idea when new version of dude will be launching ?
Same problem here, since about 3 years in different versions of Dude.
So, even reinstalling, nothing changed.
I’d try to rebuild my virtual machine, maybe could be an OS problem.
But, anyone know if it’s possible to automatically restart the web interface?
