dude won't connect on windows 10
Hello ,
I have installed dude v6.36.4 on my computer (x86) ,
but when I try to connect as localhost he said he can’t
I have disable the firewall and also open ports 2211\2210 - and nothing
what else should I do ?
Maybe you’re using a non-standard port for winbox? Then it is necessary to use it dude.
New software builds no longer have windows server option available.
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Installation#Overview
error code: 0x801901F7 on windows 10 :frowning:
i Had same problem but i change the manual port to defult port
like 8291 i start working or if not change to port 50 i hope it will be work
