I know this is probably a dumb question, but I need to ask anyway. I am trying to put together some indoor radios using the XR2 and the 411 board, but I’m having problems finding a source for pigtails. What I want is a right angle MMCX for the XR2, and an RP TNC Female bulkhead connector for a rubber ducky antenna. I can find them in China but I am not having any luck finding them here in the states. If anyone has a good source for them I would appreciate hearing from you.
It amazes me that with the popularity of both these connectors that I’m having such a difficult time finding a pigtail.
you can buy separately the connector and make a pigtail or try www.aerial.net
Or use this solution.
http://www.roc-noc.com/product.php?productid=80&cat=8&page=2
Since most indoor cases already have N holes in them, use MMCX pigtails with N-female bulkhead connector and the adapter above.
Tom
