I have a brand new CCR1036 8G 2S+ router I am having a little problem. I have a 2GB Fiber WAN connection on SFP1 and my LAN on SFP2 and on the ethernet ports. Running a speed test (speedtest.net) for example, I will get 900/900 on any of the ethernet ports, but when I connect via SFP2, I get 1200/80 or so. The same server plugged into a local SFP switch will test consistently at 10G. It is clearly a problem with the SFP2 port configuration on the mikrotik. Can you please advise? Auto negotiation is disabled, speed is set to 10G, the link shows up at 10G in the config and the light on the front of the mikrotik but any device I try into the SFP2 port will not exceed 100mbps upload, although download has been around 1200mbps or so.
What other information can I provide to be helpful? Any thoughts would be appreciated.
