DUplicate encryption setting for L2TP + IPsec
I have setup an L2TP+IPsec tunnel between sites. In PPP > Profiles I have created a profile for the tunnel which has “Use Encryption” set to yes.
in the PPP > Interface > L2TP settings I have Use IPsec = required.
Since IPsec does encryption, does the above settings mean that L2TP is also doing encryption? If not, what is the Use Encryption setting for in the PPP Profile?
It activates MPPE (Microsoft Point-to-Point Encryption), and indeed you can use the /ppp profile with no use-encryption=no if you protect L2TP using IPsec. MPPE is not considered secure enough these days so it doesn’t provide any security enhancement if used in addition to IPsec.
