My rb952 router’s DHCP server (ROS v6.46.6) is giving out the same IP address to different machines at the same time. Specifically, I have two VirtualBox VMs; when I boot them they both get the same IP address. The router’s dhcp server is configured with a pool of 10.1.65.65-96 with .65, .66 and .67 statically assigned.
Below is a Wireshark dump of the dhcp conversation (filtered on UDP between ports 67 and 68). Participants:
VM#1: 080027009A8D
VM#2: 080027AC666C
rb952 router: 64D154A36FE7 (10.1.65.254)
VM#2 was booted about 6 seconds after VM#1. VM#2 makes a dhcp DISCOVER request with MAC address (…666C) that is different than VM#1 (…9A8D) but the OFFER from the router is for the same IP address (.68) that was given out 6 seconds earlier to VM#1.
The router log file has these (abbreviated) entries:
May/15/2020 12:07:32 defconf assigned 10.1.65.68 to 08:00:27:00:9A:8D
May/15/2020 12:07:38 defconf deassigned 10.1.65.68 from 08:00:27:00:9A:8D
May/15/2020 12:07:38 defconf assigned 10.1.65.68 to 08:00:27:00:9A:8D
May/15/2020 12:17:38 defconf deassigned 10.1.65.68 from 08:00:27:00:9A:8D
Why does the second “assigned” report the same MAC address as the first (…9A8D) when the packet dump below shows the second request is from …666C?
I should mention that both VMs have the same clientid and hostname in the DISCOVER request (having been cloned from the same parent VM; but with different MAC addresses). Is it possible the the dhcp server ignores the differing MAC addresses because the clientid’s are the same? I also do not know why the packets coming from the VM are duplicated but assume this would not affect duplicate IP assignment that is the big problem?
Packet capture:
VM#1 boots and get IP address .68
#1 Time Source Destination Protocol Length Info
0.000000000 0.0.0.0 255.255.255.255 DHCP 329 DHCP Discover - Transaction ID 0x5d9f4d68
Frame 1: 329 bytes on wire (2632 bits), 329 bytes captured (2632 bits) on interface 0
Ethernet II, Src: PcsCompu_00:9a:8d (08:00:27:00:9a:8d), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 0.0.0.0, Dst: 255.255.255.255
User Datagram Protocol, Src Port: 68, Dst Port: 67
Bootstrap Protocol (Discover)
#2 Time Source Destination Protocol Length Info
0.000006277 0.0.0.0 255.255.255.255 DHCP 329 DHCP Discover - Transaction ID 0x5d9f4d68
Frame 2: 329 bytes on wire (2632 bits), 329 bytes captured (2632 bits) on interface 0
#3 Time Source Destination Protocol Length Info
0.581032219 10.1.65.254 10.1.65.68 DHCP 342 DHCP Offer - Transaction ID 0x5d9f4d68
Frame 3: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
Ethernet II, Src: Routerbo_a3:6f:e7 (64:d1:54:a3:6f:e7), Dst: PcsCompu_00:9a:8d (08:00:27:00:9a:8d)
Internet Protocol Version 4, Src: 10.1.65.254, Dst: 10.1.65.68
User Datagram Protocol, Src Port: 67, Dst Port: 68
Bootstrap Protocol (Offer)
#4 Time Source Destination Protocol Length Info
0.581217715 0.0.0.0 255.255.255.255 DHCP 341 DHCP Request - Transaction ID 0x5d9f4d68
Frame 4: 341 bytes on wire (2728 bits), 341 bytes captured (2728 bits) on interface 0
Bootstrap Protocol (Request)
#5 Time Source Destination Protocol Length Info
0.581220548 0.0.0.0 255.255.255.255 DHCP 341 DHCP Request - Transaction ID 0x5d9f4d68
Frame 5: 341 bytes on wire (2728 bits), 341 bytes captured (2728 bits) on interface 0
#6 Time Source Destination Protocol Length Info
0.582293397 10.1.65.254 10.1.65.68 DHCP 342 DHCP ACK - Transaction ID 0x5d9f4d68
Frame 6: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
Bootstrap Protocol (ACK)
VM#2 boots and gets the same .68 address.
#7 Time Source Destination Protocol Length Info
5.959033379 0.0.0.0 255.255.255.255 DHCP 329 DHCP Discover - Transaction ID 0xceb7d8a5
Frame 7: 329 bytes on wire (2632 bits), 329 bytes captured (2632 bits) on interface 0
Ethernet II, Src: PcsCompu_ac:66:6c (08:00:27:ac:66:6c), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
#8 Time Source Destination Protocol Length Info
5.959038312 0.0.0.0 255.255.255.255 DHCP 329 DHCP Discover - Transaction ID 0xceb7d8a5
Frame 8: 329 bytes on wire (2632 bits), 329 bytes captured (2632 bits) on interface 0
#9 Time Source Destination Protocol Length Info
5.987342604 10.1.65.254 10.1.65.68 DHCP 342 DHCP Offer - Transaction ID 0xceb7d8a5
Frame 9: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
Ethernet II, Src: Routerbo_a3:6f:e7 (64:d1:54:a3:6f:e7), Dst: PcsCompu_ac:66:6c (08:00:27:ac:66:6c)
#10 Time Source Destination Protocol Length Info
5.987619370 0.0.0.0 255.255.255.255 DHCP 341 DHCP Request - Transaction ID 0xceb7d8a5
Frame 10: 341 bytes on wire (2728 bits), 341 bytes captured (2728 bits) on interface 0
#11 Time Source Destination Protocol Length Info
5.987624300 0.0.0.0 255.255.255.255 DHCP 341 DHCP Request - Transaction ID 0xceb7d8a5
Frame 11: 341 bytes on wire (2728 bits), 341 bytes captured (2728 bits) on interface 0
#12 Time Source Destination Protocol Length Info
5.989030646 10.1.65.254 10.1.65.68 DHCP 342 DHCP ACK - Transaction ID 0xceb7d8a5
Frame 12: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
