Duplicate log entries
Hello there,
on my network i have duplicate log entries, exactly a mirror, short after i login on a router (see image). Mean time is about 1 minute. Like i re-logged in and log show me again the entire content.
Where i can start to have an idea of the issue? That happens on various versions of ROS, including latest.
(forgive about date not correct and psu fail, are intentional)
What rules (and actions) are defined in System → Logging ?
Nope. Clean install… BTW i’m aware of sys logging rule.
I attach for you the log screen immediately after i logged in. Normal, as one expect.
After ~1min, is like the TCP connection is re-estabilished, and winbox requires log entries again…
This happened in the meanwhile i wrote reply to you. Approx 2mins. Note that the “logged in” timestamp is the same, so no apparent reconnection from my winbox. See attachment.
Winbox ? Does web interface show the same doubled log ?
Good point.
I rarely use webfig. Really, 80 is always disabled on my routers. Webfig don’t show duplicate entries.
I try with latest winbox and keep this post updated.
TY for now.
My fault i don’t mind to check with webfig. With latest winbox it seems all fine, no dupes.
TY guys and sorry for dumb question.
