Duplicating configuration across RB's of different types
Hello, just wanted to know if there was any easy way to duplicate configuration of a RB across other models? For example I have a CCR with the config i would like to move to 1100AHx2 and 450G’s. Is there any easy method?
No. You can use export, manually correct it and import to other device.
