duration of logon pppoe server!
excuse me,
I should like know why when I make a pppoe connection between a server and a client after two hours the pppoe connection goes logout and then it make a new pppoe connection for login.
my profile:
0 * name=“default” local-address=10.1.16.1 remote-address=private_pool
session-timeout=0s idle-timeout=0s use-compression=default
use-vj-compression=default use-encryption=default only-one=default
change-tcp-mss=yes rate-limit=1000k/2500k dns-server=10.50.0.1
best regards
ALBY
What version are u using now ?? Try after upgrade with latest one.
Rafiq…
and also disable compression and encryption, that should help
I will test it and send you answer.
my version in use 2.9.38
regards
my problem is this log:
help me!
I have a great problem when I use a pc with a dual core processor and a mikrotik relese 3.6 becouse the minipci prism 2511mp plus after few seconds doesn’t make the
pppoe autentication can I have an help from you!!??
best regards
disable Multi Core support in ROS
/system hardware
set multi-cpu=no
