DVR Authroise
Hello Every body, i have host spot configured mikrotik server,guide me how can i auto authorize Internet to A CCtv DVR.how can i do it..please
1.- Go to IP > Hotspot Hosts tab. Right click on the DVR entry, and select make binding.
2.- Go to IP > Hotspot > IP Bindings tab, open the DVR entry, change its Type to bypassed.
That’s it.
You’ll have to either use an IP in the same network range, but not in the ip > pool defined for the hotspot, and set it in the binding (best practice) or make that lease static.
See http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot#IP_Bindings
You can also note the mac address of the DVR (should be on a label somewhere) and add the IP Binding entry manually.
