How do I port forward to be able to access my DVR from outside the network. I could access it through LAN but not outside.
port tcp 34567
udp 34568
http 80
DVR IP 192.168.1.100
ISP’s IP assigned to my WAN is 124.XXX.XXX.XXX
port tcp 34567
udp 34568
http 80
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Port_mapping
add chain=dstnat action=dst-nat protocol=tcp dst-address=124.XXX.XXX.XXX dst-port=80 to-addresses=192.168.1.100 to-ports=80
add chain=dstnat action=dst-nat protocol=tcp dst-address=124.XXX.XXX.XXX dst-port=34567 to-addresses=192.168.1.100 to-ports=34567
add chain=dstnat action=dst-nat protocol=udp dst-address=124.XXX.XXX.XXX dst-port=34568 to-addresses=192.168.1.100 to-ports=34568
You may need to add the following depending on your forward policy.
add chain=forward action=accept protocol=tcp dst-address=192.168.1.100 dst-port=80,34567
add chain=forward action=accept protocol=udp dst-address=192.168.1.100 dst-port=34568
Thanks a lot blake, I have gotten it to work.
How important is the second code?
It’s working without it.
If you have a deny (see below) at the end of your forward chain then you would need the second set of rules placed somewhere above that deny.
/ip firewall filter add chain=forward action=drop
Thanks again. ![]()
