1- Modem WAN (192.168.16.16) non static ip
2- RB951Ui-2HnD router (4.4.4.1)
3-LAN Pc's (4.4.4.2-4.4.4.254)
4-Wlan Pc's (5.5.5.2-5.5.5.254)
i work now very good with hotspot (user+pass)
since one week client who working banding with ip lan 4.4.4.229
want static ip to use DVR
i get static ip to this client
ip =41.x.x.182
mask =255.255.255.252
GW =41.x.x.181
ISP repair modem to work DVR
but he don't know how mikrotik work
please help me what i can do in mikrotik
i am new user
DVR work direct very good befor RB951Ui-2HnD router ( conected to mdem direct )
when i confuger DVR as ip =41.x.x.182
GW =41.x.x.181
but after RB951Ui-2HnD Not working
now internet work to all pcs - dvr non
Our ISP don’t support bridge in her modem (router)
but support 2 lan ip
ISP confugur her Modem with 2 ips
IP address :192.168.1.1
Second IP address:: 41.XX.XXX.181 (this is static gatway)
and give me for dvr 41.XX.XXX.182
i can login to modem with any one
mikrotik WAN working now as 192.168.1.1
mikrotik lan working now as 4.4.4.1
can i give DVR 4.4.4.200?
and forwording 41.XX.XXX.182 to 4.4.4.220?
or forwording 192.168.1.1 to 4.4.4.220?
Second you told us that the ISP provide you 2 ips
First IP address :192.168.1.1 [ it’s part also as private class so i this case you will not be able to access it from the internet ]
Second IP address:: 41.XX.XXX.181 (this is static gatway) [ this is public ip and you can access it from outside]
AND give me for dvr 41.XX.XXX.182 .
Are u able to access 41.XX.XXX.181 ip of the modem from outside ? If yes are you able to access your modem configuration ?
An idea it’s to set ip address ( 41.XX.XXX.182 ) to mikrotik interface .. see if you could access it from the internet .
i am sorry sir our ISP modems not support Bridge
no choice in NATpage to change PPPoe to Bridge
so i work now by this way>>>
modem working with 2 ip as gateway
192.168.1.1 ===============> modem ip login
41.XX.XXX.181 =============> modem static ip as gateway to static and login to modem too
Internet working without mikrotik
DVR working without Mikrotik
Now
i configure mikrotik like this way for 1 year
wan = 192.168.1.99/24
lan = 4.4.4.1/24 (hosts via lan)
wlan = 5.5.5.1/24 (wireless from modem)
hotspot setup
DHCP setup
firewall nat
IP dns
------------------------------- now all my network working very good via hotspot
except the new host which want DVR
DVR working and tested without mikrotik (very good)
not working with mikrotik
we work now without static ip and we not change this way
we get new static ip for DVR only not for all network
ip =41.xx.xxx.182
gateway = 41.xx.xxx.181
DNS1 =163.121.128.134
DNS2 =163.121.128.135
i just want forwarded static ip to DVR
i am sorry i can't understand from links
but i can understand from WINBOX
and:
Now you configured mikrotik 1 year ago like :
you also noted that DVR have the following IP : 41.xx.xxx.182 and if it’s connected directly to the modem can access the internet and also himself could be access it .
In this case my suggestion it’s to add secondary ip on wan interface of the mikrotik ( you can secondary ip from another network ) as the following:
wan = 41.xx.xxx.182/mask ( as secondary ip ) - also don’t forget to add static default route to 41.xx.xxx.181 ( in this case you will have two default routes )
connect the DVR to mikrotik LAN interfaces and change ip address of the DVR to one of the lan host ( 4.4.4.199/24)
At the end write the correct nat rule to be able to be access from outside where destination ip should be 41.xx.xxx.182 to nat ip ( in this case ) 4.4.4.199
1- ip >> address >> add (81.xx.xxx.182/30) interface = wan
i have now 2 wan
2- ip >> route >> gateway (41.xx.xxx.181) become ( s - 0.0.0.0/0 - 41.xx.xxx.181 reachable wan) color become blue
i have now 2 rout
3- i change DVR ip to 4.4.199/24 and now connected to Mikrotik lan
but sorry i can’t understand this step
((((At the end write the correct nat rule to be able to be access from outside where destination ip should be 41.xx.xxx.182 to nat ip ( in this case ) 4.4.4.199)))
at last i am sorry for 1 mistake
this mistake wlan = 5.5.5.1/24 (wireless from modem) = wlan = 5.5.5.1/24 (wireless from mikrotik)
because this model have wan and wlan
1.From the internet, from other system, are you able to ping ip address written on wan 41.xx.xxx.182?
2.From the local network you are able to connect to the DVR with the new IP 4.4.4.199 ( not 4.4.199) ?
If so follow the next steps to write a nat rule that will give you the opportunity to access the DVR from the internet .
Let me explain the rule create on pictures :the traffic it’s coming to Destination Nat 41.xx.xxx.182 on protocol tcp, to destination port 3999 on interface wan ( in my case internet ) will have an action destination nat to address 4.4.4.199 ( not 4.4.199 because you forgot an 4, i hope that it’s not this the ip address of the DVR ) to ports 3999 . For this rule i have selected log to be able to see in log section the status of the rule. Later you can unselected the log option .
With this rule you will be able to access the DVR from the internet when you will write on a favorite browser: http or https://41.xx.xxx.182:3999
please check if you have in firewall an input rule that will permit icmp packets. If not please add the rule before ( in font ) the rule that drop everything.
The rule that permit ping the outside interface :
Best Regards,
