Dyna damaged??
Hello.
This might be a question for the mikrotik designer…
I have bought a new dyndish from supplier today and after installing the dish i noticed two small caps.
I think when they assembled it they might have fasten the screws to tight, or the plastic is bend.
Im just worried that rain might enter the dish and do damage.
I have bought a few dynadish units in the past and it is the first time i saw this
Should i have them replace the unit or will it be ok on rainy days?
I would contact the distributor and send them the same photos, I believe the dyna series should be plastic welded together like the SXT’s etc to prevent ingress.
Hi i have contact fhe distributor and they going to replace it after submitting RMA.
In the future i will check all my new mikrotik equipment for defects before installing it.
