Hey there! I’m trying to make a wireless link between two points separed by 8KM (Google Maps) Y setup all Configuration AP station and on Client, but for some reason I can’t reach from Client my AP connection
In both sites I have the same product Dynadish 5, and here configuration:
AP
Band: 5GHz-N/AC
Channel Width: 20/40/80MHz Ceee
Frequency: 5010
Wireless Protocol: nstream
Frequency Mode: superchannel
Make Sure all Chain active and enable nstream
Client (Same than AP)
Band: 5GHz-N/AC
Frequency: 5010
Make sure all chain active
If I place both antenna in low range (10mts, for example) I can connect with no problem. But when I place on their respective spot, I can’t find it.
So, here the question: Is this antenna a good option for my requirements? Is configuration best? What am I doing wrong? Maybe it’s because aligment but… I got a reference and both antenna are aim to same reference, I know it isn’t the best, but I know than once I find the antenna I must move antennas to get the best result.
Well. Thanks! Regards
