DynaDish 5 Configuration Problem
I have DynaDish 5 with 3.5 Km P2P link but i haven’t received good throughput any one suggest right configuration… :frowning: :frowning: :frowning:
Mikrotik failure product…
What is the signal from the link?
-55
Can you post your config here
Go to new terminal and type export
Copy and paste the result here on this forum.
What performance have you?
feb/12/2016 20:16:06 by RouterOS 6.34.1
software id = 95JE-IR0S
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-eCee
disabled=no frequency=5200 frequency-mode=superchannel mode=bridge
wireless-protocol=nv2 wps-mode=disabled
add bridge=bridge1 interface=wlan1
/interface bridge settings
set use-ip-firewall=yes
add address=172.16.0.7/22 interface=ether1 network=172.16.0.0
add distance=1 gateway=172.16.0.1
/system clock
set time-zone-autodetect=no time-zone-name=Asia/Kolkata
/system clock manual
set time-zone=+05:30
/system identity
set name="IsolNet P2P-2"
/system leds
set 0 interface=wlan1
/system routerboard settings
set cpu-frequency=720MHz protected-routerboot=disabled
Set NV2 to 802.11 protocol and try this.
Let me know the result.
what throughput did you expect? what throughput did you get?
I ask him that 2 times but have no answer howmatch troughput he has.
Receive 100 to 160
Aspect 200 to 400
After 802.11 ping break problem
