ِDynadish 5 Low Bandwidth
I Use Dynadish instead of Sextant G for more bandwidth. I Estimate bandwidth about 300Mbit. But now in the best situation I have Just 220Mbit.
My Point to point link is about 200 meters. I think that I must have more bandwidth and here is my Routers Configs:
Bridge :
jan/03/1970 22:58:28 by RouterOS 6.41
software id = 4Z2C-1VK0
model = RouterBOARD DynaDish G-5HacD r3
serial number = 705D074BB683
add admin-mac=64:D1:54:5F:44:06 auto-mac=no name=bridge
set [ find default-name=ether1 ] advertise=1000M-half,1000M-full
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=profile1 supplicant-identity="" wpa2-pre-shared-key=00000000
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=15 band=5ghz-a/n/ac basic-rates-a/g=18Mbps,48Mbps,54Mbps channel-width=20/40/80mhz-eCee country=iran disabled=no distance=1 frequency=5240 frequency-mode=superchannel ht-basic-mcs=
mcs-2,mcs-3,mcs-4,mcs-7,mcs-10 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-7,mcs-10,mcs-17,mcs-18,mcs-19,mcs-21,mcs-22,mcs-23 mode=bridge nv2-cell-radius=10 preamble-mode=short radio-name=HO scan-list=5240 security-profile=profile1
ssid=MikroTik supported-rates-a/g=18Mbps,24Mbps,36Mbps,48Mbps,54Mbps wireless-protocol=802.11 wps-mode=disabled
/interface wireless nstreme
set wlan1 enable-nstreme=yes
/ip hotspot profile
add bridge=bridge hw=no interface=ether1
add bridge=bridge hw=no interface=wlan1
add address=192.168.168.132/24 interface=bridge network=192.168.168.0
Station Bridge :
jan/03/1970 22:56:40 by RouterOS 6.41
software id = 8SS6-2B9P
serial number = 705D07062DB5
add name=bridge
00000000
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=20 band=5ghz-a/n/ac
ht-basic-mcs=mcs-2,mcs-3,mcs-4,mcs-5,mcs-7,mcs-10 ht-supported-mcs="mcs-0,mc
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-7,mcs-10,mcs-18,mcs-19,mcs-21,mcs-22,mcs-23"
mode=station-bridge radio-name=BO1 scan-list=5240 security-profile=profile1
ssid=MikroTik station-roaming=disabled supported-rates-a/g=
add address=192.168.168.131/24 interface=bridge network=192.168.168.0
/ip dhcp-relay
add dhcp-server=192.168.168.254,192.168.168.168 disabled=no interface=ether1
name=HO-Relay
How much your power levels ?
Reduce power until you are at -55db
Test 802.11 instead of nstream
