I have a mikrotik running as a hotspot server. Say I want to turn off our login page for the day becuse of server maint. I would typicall go to IP/hotspot/IP bindings and just put the entire dhcp range in bypass mode. Which works fine unless someone comes in with a static IP address which then gets reassigned to an address in our IP range. These will always go to the login page unless I bind each one indivdually and put it in passthrough. Is there a way to get these dynamic Ip to be in passthrough without having to bind each one?
Why wouldn’t you just disable the Hotspot instance for the day? Much simpler than bypassing everyone.
Just to verify. Disable under IP/hotspot/servers.
Thanks..
In Winbox, yes. “/ip hotspot” on the CLI. Just disable the relevant instance and it’ll act like a normal router.
