dynamic dns in mikrotik router
I want to know how to set dns name for a system which has dynamic IP. As of now we are using Leased line internet connection for our office which give us 16 static IP’s, so all the system has static IP. Now we are intend to change to broadband connection there we won’t have static IP’s. What I want is with broadband’s dynamic IP how can I use dns to make my computer available in web for RemoteDesktop. How can I do this?
I have
Mikrotik Router 750GL.
Two 8-port switches to connect 10 systems over LAN.
Pick which ever service you want to use (no-ip, etc) and then find a script on the forums for that service. Then run the script every N minutes.
I wanted to use DynDNS:http://dyn.com/dns/ but this link: http://wiki.mikrotik.com/wiki/Manual:Tools/Dynamic_DNS says that mikrotik router doesn’t support DynDNS. Which one would be good to use with mikrotik router?
EntryDNS… DynDNS does work though. There are some scripts around here that work for that.
