Hi would you kindly take a look at this script an tell if there es anything wrong with it or if it can be optimized somehow.
Thank you.
set mandatory variables
:local username [/system identity get name ]
:local password "test"
:global dyndnsForce
:global previousIP
:log info ("previous IP is $previousIP")
get currentIP to file currentip.txt
/tool fetch mode=http url="http://ddns.xxxxxx.xxx/nic/checkip" dst-path=/currentip.txt
parse file currentip.txt for current IP
:local currentIP [/file get currentip.txt contents]
:set dyndnsForce true
Update dynlan1.de
The following checks first whether or not the currentIP matches the previousIP and based on that information either in case they don't match updates $username.xxxxxx.xxx with the currentIP or in case they do match logs that no update was needed
:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={
:set previousIP $currentIP
/tool fetch mode=http url="http://$username:$password@ddns.xxxxxx.xxx/nic/update?hostname=$username&myip=$currentIP&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG" dst-path=/dyn.txt
:log info ("Updated $username.xxxxxx.xxx to $currentIP")
:log info ("current IP is $currentIP")
} else={
:log info ("$currentIP = $previousIP No update needed!")
