Dynamic IP address
This is probably obvious, but I dont’t see how to do this. The first time I ran dude, it found the nodes of my network and properly showed their ip addresses under settings. Susequently, after taking the network down and bringing it back up, it shows the ip addresses as they were originally, not as they were dynamically reassigned.
How do I force dude to refresh the ip addresses?
Go into the device and set lookup to ‘name to IP’ or ‘IP to name’, whichever you need.
It’s possible to change your dynamic ip.Once reset your modem connection .Your modem set by new ip.If you want to check what ip address you have,visit this site Here you can get your ip location,latitude,longitude also.
