Has anyone tried this ?
http://mum.mikrotik.com/presentations/US12/tomas.pdf
It uses traffic monitor to check used bandwidth and modify routing mark dynamically.
Any thought ??
Any thought ??
It’s a good and greatly presented solution; you’ll have to decide whether it suits your scenario or not.
It works as expected. I do my configuration based on that presentation to load balance between a DSL and SAT Line. Goal was that the high latency SAT line only jump in if the DSL line are full loaded (bandwith limit are reached). It works well. Additional i add NTH strategy if both lines are full loaded.
But actual i use 4 bonded DSL Lines. The SAT is part of the past now.
Regards
Marcus
Nice to hear it from you both
There are two scenarios I can apply to :
A company with 10-15 pc sharing three equal bandwidth dsl lines
A home network with a pair of pc and a pair of adsl lines
Which solution (PCC or traffic monitor) should I choose for each environment ??
