dynamic management of bandwdth
hi all, i need to configure a script that allow routeros to automatically control bandwidth allocation on out interface.
P2P must have 6M of bandwitdh when total bandwidth consomption on out is < 25M
when total bandwidth consomption is >25M , bandwidth of P2P automatically slow down to 3M
is it possible ?
thank for your help
This should be possible using traffic monitor http://www.mikrotik.com/testdocs/ros/2.9/tools/trafmon.php. When out traffic becomes >25M script disables 6M P2P queue and enables 3M P2P queue. When out traffic becomes <25M it disables 3M queue and enables 6M queue.
ok thanks so much
is it possible to do this
system script add name=0M-up source={/queue simple enable 1
/queue simple disable 0}
if i need a script that allow to enable Queue ID 1 and disable Queue ID 2.
Queue ID 1 = P2P 6M
Queue ID 2 = P2P 3M
thank for help
You can identify your queues with names. For example, make queues named “3M_P2P_Queue” and “6M_P2P_Queue”. Then
/queue simple disable [find name="3M_P2P_Queue"];
/queue simple enable [find name="6M_P2P_Queue"];
