dynamic=no doesn't work in /ip route
Hi, i find that the follow commands get different results:
:put [:len [find static=yes]]
=>44
:put [:len [find dynamic=no]]
=>0
:put [:len [find dynamic !=yes]]
=>44
but in /ip firewall nat they have same results:
=>55
=>55
so is it a ros’s bug?
My ros version:
CHR 6.45.5
When route is not dynamic then “dynamic” parameter is not set wich is not equal to “no”
Correct way is
[admin@p3_450] /ip route> print where dynamic
 0 ADS  0.0.0.0/0                          10.155.125.1              1
 1 ADC  10.155.125.0/24    10.155.125.18   ether1                    0
[admin@p3_450] /ip route> print where !dynamic
 0 A S  10.255.0.0/24                      10.155.125.1              1
 1 A S  10.255.1.0/24                      10.155.125.1              1
Thank you for your reply.
It worked for print command, but can’t be used by find command.
I think the rule should have the same behavior both for /ip route and /ip firewall nat(and others), so it’s better to set the dynamic parameter(=no) for the static route.
Works with find too:
[admin@p3_450] /ip route> :put [find  where !dynamic]
*2;*1
[admin@p3_450] /ip route> :put [find  where !static]
*401691fd
Sorry, my fault. It works.
