All,
How can I accomplish the following without a VPN?
Dynamic IP Address (Wan)<------------> Mikrotik Router<-----------> Lan Host #1 (TCP 80, UDP 123, UDP 124), Lan Host #2 (TCP 80, UDP 123, UDP 124), Lan Host #3 (TCP 80, UDP 123, UDP 124)
Issue:
Client coming in from the Wan interface is using web browser. I understand that Port 80 traffic can be translated to another port, however the Lan Host specific UDP traffic must also remain associated with initial translation.
How do I do this?
Thanks!
Uh? Let’s start again. Please, explain in detail:
What do you have?
What do you want to have?
Whats the correct way you want this working?
Thanks for the response.
My existing environment:
I am testing an OmniTik U-5Hnd.
I have 3 Ethernet devices, one is plugged into port 3, one in port 4 and the other into port 5.
Port 1 is used as a WAN port… dynamically assigned Internet address.
The 3 Ethernet devices are all using and require TCP Port 80 for web services, UDP port 1998 for Data Streaming, UDP port 1999 for Data Streaming.
Wish:
I would like to access all 3 devices from a remote (Internet) location using a single, dynamically assigned WAN address.
Ex: http://24.12.23.12 to access the first device (and it’s UDP stream), http://24.12.23.12:81 (and it’s UDP stream) for second device, http://24.12.23.12:82 (and it’s UDP stream) for third device.
Thanks!
Read about NAT in the wiki. Use action redirect.
Martin,
I do appreciate your responses and have attempted to use redirect, however, I am sorry but I don’t understand how it can help.
I have 3 ethernet devices that use the exact same ports. I only have 1 dynamically provided external ip address.
I can get 1 host working no problem… 1:1 NAT… easy stuff… it’s host 2 and 3 that don’t work properly. When I attempt to connect to host 2 or 3, they reuse the data stream ports (1998 and 1999) from host 1, therefore displaying the incorrect data.
Thanks.
to make ‘related’ connections across IP addresses you probably have to either use address-lists, or use mangling to mark the tcp connection and somehow tie the 2 additional udp NAT rules to the initial TCP connection. I don’t know if it will happen quickly enough but maybe, depends on the sequence of events from your software.
