Dynamic Queue
I have dynamic queue which is double the speed automatically at night, but after radius upgrade to 4.2.0 isn’t working anymore, I need each time to kick the user from ppp active connection to let him connect again with the double speed, I change the NAS to COA on radius then I rebooted the router but still the same.
I think it is the radius server which has to send an disconnect packet the router, then disconnect the active session. I am having trouble to get this working so ended up using a script remove all PPP connections at night, so when they come back, new profile would be applied.
Thanks Solar,
I will try the script.
Hi Solar,
Can you send me the script ?
Hi Solar,
I am good, no need
thx
