Just wanting to know what the standard timeout for Upnp generated rules is, and if there is anyway to set a timeout on these?
i have the same doubt!
I just want to make sure if I’m allowing upnp for my users that these rules aren’t just going to accumulate over time.
I would like to know if uPnP works in v2.9.x because my devices doesn’t see the router as uPnP… ![]()
It does, I have a windows box at home that detects mine fine.
Just start with no firewall rules and ensure you can pick it up (to make sure you have it set up correctly to start with
bump
Would also like a mt reply on the following: Will upnp timeout settings be a possibility for v3? (assuming there isn’t a timeout currently which is what it looks like)
There is no timeout and there is not option to configure that.
UPnP implementation has commands to add rule and remove rule.
hello friends
same problem
Yes i use utorrent too
utorrent send command and MT make dynamic rule - that is correct - but utorrent DON`T send command to release the port
NOW we need script
come on
Any suggestions are welcome
Is there a solution now?
