we’re setting a Mikrotik AP with radius authorization behind it (freeradius), we want radius to assign VLAN-ID dynamicaly based on the criteria defined (DN in certificate, type of authorization etc.) - is there support for that in Mikrotik? If so, what is the correct way to set up that? Do I have to create all VLANs that should be tagged, or does it work automagicaly?
Basicaly, something like this will be in radius configuration (example from docs)
DEFAULT Auth-Type := EAP
Tunnel-Type = 13,
Tunnel-Medium-Type = 6,
Tunnel-Private-Group-Id = 1
Any experience will be appreciated
