Dynamically monitor FTP connections and change IP.
I want to know if FTP connections can be dynamically monitored and then dynamically replace the IP address specification for packets containing the PASV response. I want to do this because I have an FTP server on my local LAN and none of my users can establish PASSIVE FTP connections.
I see in the Filter Rules there is an option to specify FTP as the connection type but if I enable this the FTP traffic does not reach the internal FTP server. The Router OS manual for V3.0 is not finished yet so I have no idea how this FTP connection type option actually works.
Can anyone help?
Simon
did you enable ‘ftp’ under ip-firewall-service ports?
Hi
It is enabled.
My rules look like this:
Filter:
17 chain=customer action=accept in-interface=ether3 dst-port=21 protocol=tcp
connection-type=ftp
NAT:
13 ;;; FTP Forward to HSTB-SME
chain=dstnat action=dst-nat to-addresses=192.168.201.10 to-ports=21
in-interface=ether3 dst-address=196.212.XXX.XXX dst-port=21 protocol=tcp
connection-type=ftp
If i disable the connection-type specification it allows me to connect but cannot establish the passive connection. The above connection says the following:
[root@spike ~]# ftp 196.212.XXX.XXX
Connected to 196.212.XXX.XXX.
421 Service not available, remote server has closed connection
ftp> quit
Any other ideas?
you do not need dst-nat rule - Service Port do it for you
How does the traffic get to the FTP server on the local LAN then? Remembering that I am running a separate ftp server, not a server on the MT firewall.
Filter:
connection-type=ftp
You need to accept related and established connections
Ok! I disabled the connection-type=ftp. Accept related and established connections and it is now working.
Thank you for your assistance.
Heres a virtual beer
:smiley:
Simon ,
Can u help me with the rule for passive ftp im not able to get it on function
Thanks on advanced
I have an ftp on a DMZ and nat ports 20 -21 active ftp works ok but passive not
try to enable ftp nat helper (Firewall->Services) and add ‘accept related connections’ rule to firewall filter
Hi SImon,
can you post your definitive sule set?
