I´m currently using a SmartDNS(smartdnsproxy) service to Watch Netflix since now Netflix decided to ban VPN´s and this SmartDNS service is still working, but I still wan´t to use my VPN for Anonymity and security so here is my question:
What is your recommendation for a dynamic DNS Script(Im using FW6.34) and what service should I use, no-ip, Dyndns(all ready have account) to show my VPN´s IP address not my Gateway IP address, since that is what I seem to be getting, unless I mark Add Default Router to my VPN Interface, but I don´t wan´t to Mark it because some times the VPN does not work and I wan´t internet traffic flow trough my WAN interface when my VPN is down as normally it does with out marking add default route.
This StartDNS Proxy has an cool unattended feature, you can see it in the picture, it checks the host that I specify and updates itself every few minutes, most other SmartDNS services need to attend to the landing page if the address changes and you have to update the IP address manually, I think this is a great feature of SmarDNSProxy, because I don´t have to do anything as long as my dynhost resolves to my VPN IP address not my PublicIP, I tried the built in Cloud DDNS feature, but there is no option to select the Interface that it will use to resolve.
thanks for the help in advice!
Ivan.
