DynDNS Script from Mikrotik Wiki (correction)
Hi all,
I’m new to Mikrotik. I just bought the HAP AC2 and i’m on the configuration period. I have set this router as the main router of my home network which also connects to the internet via PPPoE through the ISP modem. I have also set up Pi-Hole as the local DNS. While i was trying to find a script for updating my DynDNS domain i found in the official wiki a page with a script for this purpose. https://wiki.mikrotik.com/wiki/Dynamic_DNS_Update_Script_for_No-IP_DNS. I tried the script several times with no success but after some debugging i noticed that firstly, the router couldn’t resolve the domain (http://dynupdate.no-ip.com/) so i found out that the user must have set a DNS IP address under IP->DNS->Servers (maybe this must only be set up in the case you are using a local DNS as i do) and the second one was that the $previousIP variable in the script it seemed that on each run didn’t have the previous value. So i noticed here that the suggested permissions write, test, read wasn’t enough for the global variable to be set. So i granted policy permissions also and now everything works.
If the $previousIP is not set then on each run the script will send an ip update request to the DynDNS server even when the ip has not be changed (this is only noticeable though the logs. Otherwise the user is not affected)
So these two are suggestions if you are interested to be added in your official wiki page.
Thanks,
Haris
You can use MikroTik Colud DNS, its free. Then you can point your dyndns to the MikroTiok clod DNS name. (if its possible)
Or drop dyndns and only use Mikrotik Cloud DNS as your public DNS name.
IP->Cloud DDNS Enable.
Then you should get a fixed DNS name like this:
PublicIP: 65.232.13.123 (your outside IP)
DNS Name: 6f3806exxxxx.sn.mynetname.net (Serial number your router + .sn.mynetname.net)
Hello
Make script call DynDns and paste this
Set needed variables
:local username "YOURUSERNAME"
:local password "YOURPASSWORD"
:local hostname "YOURHOSTNAME.dyndns.org"
:global dyndnsForce
:global previousIP
print some debug info
:log info ("UpdateDynDNS: username = $username")
:log info ("UpdateDynDNS: password = $password")
:log info ("UpdateDynDNS: hostname = $hostname")
:log info ("UpdateDynDNS: previousIP = $previousIP")
get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:delay 1
:local result [/file get dyndns.checkip.html contents]
parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "" -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info "UpdateDynDNS: currentIP = $currentIP"
Remove the # on next line to force an update every single time - useful for debugging,
but you could end up getting blacklisted by DynDNS!
#:set dyndnsForce true
Determine if dyndns update is needed
more dyndns updater request details http://www.dyndns.com/developers/specs/syntax.html
:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={
:set dyndnsForce false
:set previousIP $currentIP
:log info "$currentIP or $previousIP"
/tool fetch user=$username password=$password mode=http address="members.dyndns.org"
src-path="nic/update?system=dyndns&hostname=$hostname&myip=$currentIP&wildcard=no"
dst-path="/dyndns.txt"
:delay 1
:local result [/file get dyndns.txt contents]
:log info ("UpdateDynDNS: Dyndns update needed")
:log info ("UpdateDynDNS: Dyndns Update Result: ".$result)
:put ("Dyndns Update Result: ".$result)
} else={
:log info ("UpdateDynDNS: No dyndns update needed")
then run this in command
/system scheduler
add interval=1m name=DynDns on-event=DynDns policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api start-time=startup
Thanks for the script.
Use code tags. Select text and click the </> button.
Like this: (with tabs as well)
# Set needed variables
	:global dyndnsForce
	:global previousIP
# print some debug info
# get the current IP address from the internet (in case of double-nat)
	:delay 1
# parse the current IP result
	:local endLoc [:find $result "</body>" -1]
# Remove the # on next line to force an update every single time - useful for debugging,
# but you could end up getting blacklisted by DynDNS!
# Determine if dyndns update is needed
# more dyndns updater request details http://www.dyndns.com/developers/specs/syntax.html
		/tool fetch user=$username password=$password mode=http address="members.dyndns.org" \
		src-path="nic/update?system=dyndns&hostname=$hostname&myip=$currentIP&wildcard=no" \
		:delay 1
	} else={
hi I am new here, I got software routeros 4.86.1 and in my IP section, I did not see “IP cloud” feature in the list , I like to use my dynamic service with dyndns, can anyone can help me to get this feature back to IP section ?
I guess, you have 6.48.1 and Cloud should be there.
In Winbox (3.27) it looks like this:
I noticed that if I changed the IP in my dyndns.org account. This script would not correct it.
To fix that, I made these changes.
:local dyndnsForce
:local previousIP [resolve $hostname]
Now the script truly compares the routes current IP with that resolved by $hostname
Hi guys,
Thanks for the script, it works. How to hide credentials in LOG file?
Every minute he sends user/pass/hostname to log file.
Thanks for the help
Remove one or all of these lines:
Great!
Thanks for your selfless help :slight_smile:
Just came across this and the script is really helpful!
Would like to share a modified version that uses the new API (using Client Update Key) and gives a warning if forced update is turned on in case anyone is interested.
Tested with RouterOS 7.2.3
	:local username "DYN_USER_NAME"
	:local clientkey "DYN_CLIENT_KEY"
	:local hostname "HOST_TO_UPDATE"
	:global dyndnsForce
	:global previousIP
	:delay 1
# more dyndns updater request details https://help.dyn.com/remote-access-api/perform-update/
	:log info "UpdateDynDNS: previousIP = $previousIP"
	:if ($dyndnsForce = true) do={ :log warning "UpdateDynDNS: Forced update on" }
		/tool fetch mode=https \
		url="https://$username:$clientkey@members.dyndns.org/v3/update?hostname=$hostname&myip=$currentIP" \
		:delay 1
	} else={
Hi everyone,
I’m currently facing an issue with my MikroTik router after updating the firmware to version 7.12.1 a few days ago. I’m using the latest script with a DNS client key, and since the update, the DynDNS is not updating correctly.
The strange part is that the router indicates a successful update, showing the new IP, but when I check on the DynDNS website, the new IP is not assigned. I’ve already tried generating a new key, but unfortunately, that didn’t resolve the issue.
I’m reaching out to the community to see if anyone else is experiencing similar problems or has any insights into resolving this issue. Could it be a problem on the DynDNS side, or is there something specific to the MikroTik FW 7.12.1 update that might be causing this discrepancy?
I appreciate any assistance or advice you can provide.
Thank you in advance for your help.
I’m facing this exact same problem.
I’m facing the same issue, worked fine untill update to 7.11.2 version. Has anyone found a solution for the problem?
Hey, sorry for my possibly bad English, I use a translator.
I did the update to 7.13 yesterday and also had problems with the script execution for dyndns.
I was able to solve the problem by activating “FTP” in the script.
I hope that this is perhaps also your problem and can be remedied.
Greetings Patty
With “ftp” the script don’t work too, but only for IPv6.
IPv4 works fine.
im facing the same issue.
any solutions already available?
got ROS 7.13 running and got a dyndns account
thx and BR
I face the same problem, thought that was my misonfiguration.
[/ip address get [find where interface=$theinterface] value-name=address] does also not show my current ip.
Interface can have multiple addresses, so the script is bad at the start…
