I am trying to get my dyndns provider work but no luck.
I have used the script from official mikrotik wiki.
My problem is that when i am run the script i get no logs.
My Script:
:global ddnsuser “xxx”
:global ddnspass “xxx”
:global theinterface “ether1”
:global ddnshost xxx.com
:global ipddns [:resolve $ddnshost];
:global ipfresh [ /ip address get [/ip address find interface=$theinterface ] address ]
:if ([ :typeof $ipfresh ] = nil ) do={
:log info (“DynDNS: No ip address on $theinterface .”)
} else={
:for i from=( [:len $ipfresh] - 1) to=0 do={
:if ( [:pick $ipfresh $i] = “/”) do={
:set ipfresh [:pick $ipfresh 0 $i];
:if ($ipddns != $ipfresh) do={
:log info (“DynDNS: IP-DynDNS = $ipddns”)
:log info (“DynDNS: IP-Fresh = $ipfresh”)
:log info “DynDNS: Update IP needed, Sending UPDATE…!”
:global str “/nic/update?hostname=$ddnshost&myip=$ipfresh&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG”
/tool fetch address=members.dyndns.org src-path=$str mode=http user=$ddnsuser
password=$ddnspass dst-path=(“/DynDNS.”.$ddnshost)
:delay 1
:global str [/file find name=“DynDNS.$ddnshost”];
/file remove $str
:global ipddns $ipfresh
:log info “DynDNS: IP updated to $ipfresh!”
} else={
:log info “DynDNS: dont need changes”;
