I have been using the DynDNS update script from the forums and it seems everything works fine. I just want to know how do I point the update script to work over a specific PPPOE interface. Currently I uses two PPPOE out interfaces and routes force the first one to be default for browsing. I want the Dyn DNS script to update the second PPPOE interface ip to DNS name.
I currently is using the following script:
__
_# Set needed variables
:local username “DYNDNSUsername”
:local password “DYNDNSPassword”
:local hostname “DYNDNS Domain Name”
:global dyndnsForce
:global previousIP
\print some debug info
:log info (“UpdateDynDNS: username = $username”)
:log info (“UpdateDynDNS: hostname = $hostname”)
:log info (“UpdateDynDNS: previousIP = $previousIP”)
\get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address=“checkip.dyndns.org” src-path=“/” dst-path=“/dyndns.checkip.html”
:local result [/file get dyndns.checkip.html contents]
\parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result “” -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info “UpdateDynDNS: currentIP = $currentIP”
\Remove the # on next line to force an update every single time - useful for debugging, but you could end up getting blacklisted by DynDNS!
#:set dyndnsForce true
\Determine if dyndns update is needed
more dyndns updater request details available at > http://www.dyndns.com/developers/specs/syntax.html
:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={
:set dyndnsForce false
:set previousIP $currentIP
/tool fetch user=$username password=$password mode=http address=“members.dyndns.org” src-path=“/nic/update?hostname=$hostname&myip=$currentIP” dst-path=“/dyndns.txt”
:local result [/file get dyndns.txt contents]
:log info (“UpdateDynDNS: Dyndns update needed”)
:log info ("UpdateDynDNS: Dyndns Update Result: ".$result)
:put ("Dyndns Update Result: ".$result)
} else={
:log info (“UpdateDynDNS: No dyndns update needed”)
}_
Where will I specify the PPP-out1 to be used as interface for IP
Thank you for your help.
