Also guys a link from where I can buy the supported hardware would be great. I also need DS3 PCI cards for the mikrotik has anyone used any card with success ???
Description
FarSync PCI V.35/X.21 (8.448 Mbit/s)
LMC/SBEI wanPCI-1T1E1 PCI T1/E1 (also known as DS1 or LMC1200P, 1.544 Mbit/s or 2.048 Mbit/s)
LMC/SBEI wanPCI-1T3 PCI T3 (also known as DS3, 44.736Mbit/s)
Sangoma S5141 (dual-port) and S5142 (quad-port) PCI RS232/V.35/X.21 (4Mbit/s - primary port and 512Kbit/s - secondary ones)
Have an SBE DS3 card in a Mikrotik 2.9.51 router. It will run fine for anywhere from 12 to 96 hours before locking up hard. Monitor will not even wake up. Tried it on two totally different sets of hardware as well with same story.
They were very responsive the last time I contacted them. Trouble is there drivers are not included in the linux kernel so Mikrotik does not support them. Problem is DS3 circuits are not at all common in Europe where Mikrotik is so its hard for them to test anything like that. At least thats what I understand of it. Likely just not enough people asking for DS3 support on Mikrotik anymore.
You might contact Sangoma just for the heck of it. The more people asking for this the better. Perhaps someone can buy a $couple$ of cards and donate them to Mikrotik. Too expensive for me though.
I would suggest to use Farsync cards as manufacturer is still producing cards, and you can still buy them new, also, they are providing driver for new kernel used in RouterOS, while others have stopped producing cards years ago, and all you can do is buy used ones, that might or might not work. (from listed as supported cards)
