Hi all,
I want to transmit one E1 link and the distance is 30 Km.
Which routerboard and also specific configuration is good and suitable for doing this issue ?!
Regards
Hi all,
Regards
You already posted this. http://forum.mikrotik.com/t/e1-transmition-via-mikrotik-wireless/44251/1
Yes, I did not get any proper answer and I sent it again.
I want to do it on MikroTik, not any other brands.
anyone ?
So then I assume you want to transport it as native TDM. You can’t do that using MikroTik, but I already told you that once.
In fact I want to transport TDM over IP (TDMoIP).
Does MikroTik support this one ?
I have E1 transmission with the following configuration:
E1 - IPMUX-2L - RB433AH - - - 3km- - - RB433AH - IPMUX-2L - E1
I’m using nstreme-dual link between the RBs. Transmission is rock solid, has 322 days uptime at now.
regards, Gabor
TDMoIP, and the IPmux you mention would imply RAD products…something he said he does not want to use.
