E50UG os downgrade
Hello everyone!
Is it possible to downgrade the os from version 7 to 6?
On version 6 , user manager is very easy configured but on 7 seems really confusing…
You can’t downgrade below factory firmware. What is the version?
Besides, from the website:
https://mikrotik.com/product/hex_2024
Why would you want to downgrade?
Because I cannot correctly setup user manager in version 7…
I knew how to do it on 6.
I want to create profiles of 1GB total data use but I don’t know how to!
I have read that comes with version 7 but I will first power up in a few minutes to check for sure .
E50UG = Hex Refresh.
Comes with ROS 7 out of factory.
No way to go back to ROS6 on this one.
So as it seems I have to find a way setup on version 7…
Seems a nightmare to me .
I will ask for help on the correct topic .
Maybe I can export my configuration from version 6 and upload it in the topic and somehow someone can help me .
Thank you all for assistance!
In the long run, it is worthwhile to learn the new user manager, which is much more powerful: https://help.mikrotik.com/docs/spaces/ROS/pages/2555940/User+Manager
There is even a migration guide in the page.
Yes but if I setup on version 7, I see that there is no web interface anymore .
How the user will be able to check his balance without ??
I dont use it but:
https://help.mikrotik.com/docs/spaces/ROS/pages/2555940/User+Manager#UserManager-WEBInterface
Thats V7 docs and mentions:
user/user_dynamic.html Layout of the user’s profile page.
So , I have lost my entire day but after many resets and many changes I made it :slight_smile:
It’s not enough to make a limitation profile and bond it with profile but you have to made it also on user group …
Very very tricky procedure but when you do it it’s clear .
It should be easier and better described on the manual .
Good news is that I like more this version 7 user manager from previous on 6.
Thanks once more for your assistance.
