I'm looking for some advice before assuming my router is permanently dead.
I have a MikroTik hEX S 2025 (E60iUGS) that appears to have been bricked immediately after an official firmware upgrade.
Logged into the router using WinBox.
Updated RouterOS to the latest stable version.
After the update, WinBox showed the "RouterBOARD Upgrade" button.
The router requested a reboot.
After rebooting, it never came back.
Current symptoms
Only the blue power LED stays solid.
No Ethernet port LEDs at all.
No physical link on any Ethernet port.
The Reset button appears to have no effect.
Netinstall never detects the device.
What I've already tried
Holding the Reset button before applying power.
Holding Reset for over 30 seconds after applying power.
Multiple Netinstall attempts.
Different Ethernet cables.
Different PC.
Static IP configured correctly for Netinstall.
Firewall disabled.
The router has remained unplugged for several hours before trying again.
The behavior is always identical: solid blue power LED only.
There was no power loss during the upgrade. The upgrade was performed entirely through the official WinBox interface. The router was working perfectly before the reboot.
Has anyone experienced this on an E60iUGS?
Is there any recovery method besides Netinstall?
Does this model have any hidden recovery procedure if RouterBOOT fails?
Unfortunately there is absolutely no difference between the two methods.
Whether I hold RESET before power, press RESET 0.5 seconds after power, or never press RESET at all, the behavior is identical.
The blue power LED turns on immediately and stays solid forever.
Netinstall never detects the device, and there is no visible indication that the router is executing anything. Just the solid blue power LED.
Even if Netinstall can't detect the device, I would still expect some indication that it's attempting to boot, such as Ethernet LEDs or any change in behavior, but the only thing I see is the solid blue power LED, which remains unchanged indefinitely from the moment power is applied
when the router switches to netinstall mode, the lan1 port will blink green, but if the lan port or USR LED does not even light up, it only indicates a 'brick'
overall, I'm not surprised.. another disadvantage of the many in the EN7562CT series
