Each client receives two IP addresses
We have set up a hotspot using a MikroTik router. Everything works fine, but we noticed that each client recieves two IP addresses, one is listed under DHCP Server / Leases and the other under Hotspot / Active. Is that normal?
This is normal if you have enabled “universal client” in hotspot. To disable this feature, set the “address pool” to “none” for the appropriate hotspot server.
