Hello Everyone!
I saw this feature “wifi - added “eap-identity” to registration table” in RouterOS v7.19 but when I upgrade my device CCR2004 then don’t see the column “EAP-Identity” in the registration table.
How to show this column?
Some columns are hidden by default. Either right click the column headings or look for some kind of icon at the very right of the headings, I can’t quite remember. One of these methods should display a checklist where you can select which columns are displayed.
Thanks for your replaying but i couldn’t find the column “EAP Identity”
It’s not yet available in WinBox but you can see the column with the print command:
