EAP on virtual AP on two separate RADIUS
Hello
Is it possible to create two or more Virtual APs and point each of their respective security profiles(using EAP) to two separate RADIUS??
No. On ROS AFAIK you can define more than one radius, but 2nd, 3d only will get used if previous one doesn’t respond.
You can however setup proxying on your radius and “route” from there.
in that case username or realm or something have to be known. right?
So like @abc.com go to one server and @def.com go to other server
That’s it, that could be a way.
thanks for your help pukkita
But the problem is I dont have a known distinguisher for the users
A customer has a setup where sstp uses two different radius servers depending on the domain-part of the username. I would think that wlan would give similar behavior in respect to domain name.
The only thing I did to make it work was to enter domainname for each radius server. I’ll post config here, in case you want to test.
/radius
add address=10.60.255.220 domain=SALES secret=Radiuspass service=ppp
add address=10.61.6.212 domain=ADM secret=Radiuspass service=ppp
the windows full domain names are sales.company.local and adm.company.local. The IP’s is the ip of a domain controller in each domain.
