As I know that there is no basic support for EAP-SIM method of authentication, but is there any possibility to make this kind of authentication using MT ?
Regards,
Ilija
Regards,
Ilija
Where do you want to use EAP-SIM at RouterOS?
I would like to use it on the RouterBoard, instead of eap-tls.
(if I understanded your question correctly)
So do you think that it could be done ?
Regards,
Ilija
MikroTik RouterOS as AP can forward any type of EAP, the RADIUS server and client should support the method.
MikroTik RouterOS as client can work with EAP-TLS.
Sergejs, thank you very much for your time and explanation. I was worried if the EAP-SIM would be forwarded toward my Radius server, but If it is as you say than “it can support EAP-SIM as it is!”.
RouterOS AP supports EAP-TLS, but EAP-SIM should be forwarded to RADIUS server.
RouterOS AP can forward any type of EAP to the RADIUS server.
Configuration for EAP-xxx should be present on RADIUS server.
Can we set up a EAP-SIM authentication with Mikrotik’s User Manager?
No, currently UserManager does not support EAP.
