EAP-TLS problems
I’m trying use built in Mikrotik Radius server. I generated certificates according to http://wiki.mikrotik.com/wiki/Manual:Create_Certificates. On client PC machine i installed myCa and client1 certificates. In Mikrotik security profile i set authentication type to WPA2 EAP. EAP Methods: EAP-TLS, TLS Mode: verify certificate, TLS Certificate: client1 (i’m not sure which side of certificate it is verifying, because i didn’t generated certificate on client machine).
When i try to connect with PC it is asking for username and password. I think it should not be using password in EAP-TLS mode.
What does export-passphrase do in exporting certificate?
Nobody implemented EAP-TLS?
