does mikrotik support EAP-TTLS PAP for 802.11x authontication?
The hotspot service supports it.
/ip hotspot profile
set 0 login-by=http-pap
if you want to use it on the wireless AP then you need to enable the radius mac authentication and configure wireless security to use WPA1/2-EAP and in the EAP settings configure to use the eap-methods=passthrough. Then configure the radius client to connect to your Radius server. Then all you need is to configure your RADIUS server for your specific needs.
thank you for the support ![]()
Hi Folks,
Can I use Mikrotik Userman to manage EAP authentication for my companies laptops for wireless purposes using non-mikrotik wireless access points (I should add that the AP’s have a radius client and industry standard EAP features)?
Uldis says yes with “A” RADIUS server but he is not clear if this is Mikrotik Userman RADIUS server?
Thanks,
Alex
http://forum.mikrotik.com/posting.php?mode=smilies&f=2#
I would like to apologise for not searching the forums properly. The very next thread I looked at says that userman cannot do what I want.
Here is the post: http://forum.mikrotik.com/t/using-usermanager-as-radius-for-other-ap/20825/1
Sorry folks,
Alex
