Hi people,
I am trying to setup EAP protocols. Especifically, EAP-TTLS agains my RADIUS Server. Does MT support EAP protocols in its wireless interface?
If I put a Orinoco AP-4000 which supports EAP protocols in suscriber interface of MT, how can my AP-4000 access to the radius servir located in Internet?
An another question, in the schema:
client -----> AP-4000 ------> MT -------> RADIUS
Are EAP packets transparent for the MT or is the a firewall?
I have the same problem, it seems that Mikrotik’s Radius server has no options for EAP-TTLS or EAP-PEAP. It has only options for WEP and WPA-PSK… or I can not find it also. ![]()
