I have working a hAP ac^2 very well but I’d like to improve the wireless connection. I have a couple of EAP245 but I’m not sure how to setup them.
I have connect both by ethernet to hAP ac^2 and setup with the same SSID and password, is this enough? Could I create a “mesh” network wiht these devices to get roaming?
I don’t know if I need to put the same channel on all devices, AP and Mikrotik, or if I have set more options on Mikrotik.
Besides SSID and password, you have to make sure that encryption is identical (WA+PA2/AES only).
Channels should never overlap. And make sure that tx power is optimized.
