I want network 192.168.8.0/24 to access the internet through gateway 192.168.2.137
and network 192.168.9.0/24 to access the internet through gateway 192.168.2.138
this is easier than I thought it would be! thanks surfertim..
well, now it works however why cant the users in the network cannot see each other? ex. 192.168.9.1 cannot see 192.168.9.2 , is there something to do with passthrough?
They should be able to see each other. Check “/ip address” for correct ip/netmasks. If clients get ips through dhcp, check “/ip dhcp-server network” to insure all is ok there. If you have questions, post both.
