easy way to export winbox log?
since you cant copy or paste from the log for some reason,
other than syslog,
what is the best way to quckly get the log out of winbox for searching or editing?
thanks
new terminal
/log print :slight_smile:
thanks,
that is not easy alo, typing shift D or d does not give me a dump.
I need to be able to search the log and have its contents outside of winbox..
also why dont ctrl command work in winbox fields? like copy and paste genearlly do not work.
in winbox open terminal, then:
[normis@demo.mt.lv] > /log print file=log
open ‘files’ and drag the log.txt file to your desktop.
beautiful! cant believe i forgot about piping…
thanks
