I’m not sure about correct setup of packages for RB4011iGS+5HacQ2HnD to achieve two networks on 2.4GHz and two on 5Ghz. All of them as AP (2 intern and 2 for guests)
Right now I updated to 7.19beta6 and use default 2 packages: routeros and wireless
But I can’t not setup new WiFi due to empty drop down menu for “Master”.
Can I overcome it with terminal or it’s not just a WebBox glitch but failing compatibility?
If so, which package should I use, to keep both frequencies working?
using the package “wireless” you use the menu “wireless” (right below wifi).
using the package “wifi-qcom” or “wifi-qcom-ac” you use the menu “wifi”.
RB4011 supports wifi-qcom-ac BUT WITHOUT the 2.4ghz interface
Thank you for the clarification.
