ECMP (Equal Cost Multi-Path) question
Hello I have made the settings for ECMP (Equal Cost Multi-Path) in my network. All It works but I would need to know if there is a way to make that a client has only one gateway and is not balanced somenthing like this:
GW1 client1
GW2 Routerboard with ECMP client2
GW3 client3
I need that client3 goes on the internet always from GW3.
cetalfio
In the wiki you have a example.
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
Send from my mobile phone using Tapatalk.
Yes question solved.
