Hello friends,
I would ask for help with ECMP. I have two radio links. each with 150 MB = 75/75, I’m trying to use ECMP to balance traffic between them. below is the illustration of my scenery, art works, most not in the manner which I expect when I do this way, UP Wlan1, Wlan 2 Down , I would like to know as a way of balancing the two radios in equal parts, using UP X 2 x 2 Down. thus spreading in equal parts. at each end after the radios have 2 rbs 1000, I am grateful for the help:)
sorry for the English translator by Google…
up
instead of bumping the post (which is annoying) you should think about why nobody has answered, and maybe provide better information and better defined questions.
You already use ECMP via the multiple gateways option, but you can also try to use Policy routing to send only specific traffic through each gateway.
And if both devices are yours and mikrotik, you can even try to use bonding.
sorry for the topic boring guy, thanks for the tip =)
