Hello Members,
Need help with load balancing.
I have setup ECMP:
WAN 1 - 2.2.2.2
WAN 2 - 3.3.3.3
LAN 1 -
- USER 1 - 192.168.1.10
- USER 2 - 172.16.1.11
- USER 3 - 172.16.1.12
- USER 4 - 172.16.1.13
- USER 5 - 192.168.1.14
What I want to achieve is USER 1 & USER 5 to always reach WAN 1 as these USERS have been assigned static IP’s where as the other user are on dynamic.
How do I go about this?
Please help.
Thank you.
Sent from my SAMSUNG-SM-G935A using Tapatalk
You need to use policy based routing, either by using policy rules:
/ip route rule add src-address=172.16.1.11 action=lookup table=ISP01_OUT
or via the mangle facility in the firewall:
/ip firewall address-list add list=ISP1_CLIENTS address=172.16.1.11
/ip firewall mangle add chain=prerouting action=mark-routing new-routing-mark=ISP01_OUT src-address-list=ISP1_CLIENTS
Either way you’d need to add 2 separate default routes into 2 other routing tables.
/ip route add gateway=ISP01 routing-mark=ISP01_OUT
This is just a basic stanza, there are other ways to accomplish this that take into account your current setup.
Read this for more info:
https://wiki.mikrotik.com/wiki/Policy_Base_Routing
Thanks Shao for the help..
